Usb hub usb2514 implementation doubt
Jishnu Rajeev
Newbie level 3
Newbie level 3
Usb hub usb2514 - implementation doubt
I'm using USB2514 to design a BUS powered system which has 3 devices to be connected at present . My doubt is regarding the SUSP_IND/LOCAL_PWR/NON_REM0 pin .
My system is bus powered so the pin has to be LOW . The device on my port 1 is non removable so the pin has to be HIGH . How this can be implemented ?? ( I know NON_REM0 is asserted only during RESET_N ... )Any RC arrangement or something like that . . I'm bit confused in this .
The datasheet link is : **broken link removed**
