USB host controller, non-PCI
davorin
Advanced Member level 3
Switzerland
philips flexistack
Someone knows any other non-PCI USB host controllers than Philips, Cypress and TDI?
Cypress SL811 is only 8-bit, Philips has driver problems with Linux and driver source for TDI´s TD242 is US$ 15000 (o;
More info...
The host driver, flexistack, from philips is $ 40.000, on the philips site you get the idea that its cheaper but its not...
The cypress usb solution folows the usb 2.0 standard but does not suport 480 Mbit Hi-Speed.
Also searching for a host controller with host stack but it should be PCI, programming/buying the stack seams to be the expensive part...
re Me
