Rajinder1268
Full Member level 3
Hi all,
I have attached a copy of a schematic that I am working with. The schematic with the usb type A connector is connected only sometimes to a PC.
I need to use the type A usb to power a second set of electronics, which will be connected to a micro usb.
My questions:
1. Do I need to have ESD/EMI filtering for this extra circuit?
2. I have measured the noise from the USB5V, it is pk-pk 186mV, I was thinking of a LC or PI filter before it is connected to my 3V LDO.
3. Lastly the micro USB is 5 pin, it has an extra pin called ID, what do I need to do with this pin?
Thanks in advance.
My questions:
Thanks in advance.
