USB hardware key issues with WinXP SP2
alanj@signalcrafters.com
Junior Member level 1
I’m using ModelSim 6.1 PE+ Node-locked license with a USB hardware key. It worked fine on a couple of different computers (WinXP SP2). I got a new computer this week and it’s not working on it. The flexlm (Aladdin drive) fails to load the license file is says. The guys at ModelSim say SP2 has a lot of problems. Did anyone else have this problem?
Alan
Re: USB Hardware Key
when you say USB harware key .Do you mean a USB -> ethernet adaptor ??
USB to what ? USB is a BUS .
usd dongel is also being used for modelsim license validation.
have you tested the license server link to modelsim?
you can use flexlm diagnostic tools for this job.
hock
