M3GAPL3X
Junior Member level 3
usart 8mhz
Hi guys,
I am currently using a LFINTOS (Low Frequency Internal Oscillator) set at 31 kHz as my main clock source. Eventually in my program, I will be needed to transmit some data through USART. From what I have been reading, I might not be able to use 31 kHz to achieve this - mostly due to baud rate generation. Is there a way I can switch clocks when I want to transmit data and go back to 31 kHz?
Any hints or guidance would be appreciated.
Hi guys,
