aminpix
Full Member level 2
I am trying to develop a simple UART interrupt code based on PS on Zynq. The plan is when the Zynq receives any character from RX_UART, take it and send it back to the TX_UART line.
It has to be with interrupt.
It looks very simple buy almost weeks I cant find solution for it.
Anyone can help me! This code doesn't do anything!
Here is my code.
Here is my code.
C:
#include <stdio.h>
#include "xparameters.h"
#include "xil_printf.h"
#include "xuartps.h"
#include "xscugic.h"
#define UART_DEVICE_ID XPAR_XUARTPS_0_DEVICE_ID
#define INTC_DEVICE_ID XPAR_SCUGIC_SINGLE_DEVICE_ID
#define UART_INT_IRQ_ID XPAR_XUARTPS_1_INTR
#define RECV_BUFFER_SIZE 3
XUartPs UartPs ; /* Instance of the UART Device */
static XScuGic InterruptController; /* Instance of the Interrupt Controller */
int UartIntrInit(XScuGic *IntcInstPtr, XUartPs *UartInstPtr, u16 DeviceId, u16 UartIntrId);
static int SetupInterruptSystem(XScuGic *IntcInstancePtr, XUartPs *UartInstancePtr, u16 UartIntrId);
void UARTHandler(void *CallBackRef, u32 Event, unsigned int EventData);
static u8 RecvBuffer[RECV_BUFFER_SIZE]; /* Buffer for Receiving Data */
int main(void)
int Status;
Status = UartIntrInit(&InterruptController, &UartPs, UART_DEVICE_ID, UART_INT_IRQ_ID);
if (Status != XST_SUCCESS)
xil_printf("UART Interrupt Example Test Failed\r\n");
return XST_FAILURE;
while(1);
return 0;
int Status;
XUartPs_Config *Config;
u32 IntrMask;
* Initialize the UART driver so that it's ready to use
* Look up the configuration in the config table, then initialize it.
Config = XUartPs_LookupConfig(DeviceId);
if (NULL == Config) {
return XST_FAILURE;
Status = XUartPs_CfgInitialize(UartInstPtr, Config, Config->BaseAddress);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
/* Check hardware build */
Status = XUartPs_SelfTest(UartInstPtr);
return XST_FAILURE;
* Connect the UART to the interrupt subsystem such that interrupts
* can occur. This function is application specific.
Status = SetupInterruptSystem(IntcInstPtr, UartInstPtr, UartIntrId);
return XST_FAILURE;
* Setup the handlers for the UART that will be called from the
* interrupt context when data has been sent and received, specify
* a pointer to the UART driver instance as the callback reference
* so the handlers are able to access the instance data
XUartPs_SetHandler(UartInstPtr, (XUartPs_Handler)UARTHandler, UartInstPtr);
* Enable the interrupt of the UART so interrupts will occur, setup
* a local loopback so data that is sent will be received.
IntrMask =
XUARTPS_IXR_TOUT | XUARTPS_IXR_PARITY | XUARTPS_IXR_FRAMING |
XUARTPS_IXR_OVER | XUARTPS_IXR_TXEMPTY | XUARTPS_IXR_RXFULL |
XUARTPS_IXR_RXOVR;
XUartPs_SetInterruptMask(UartInstPtr, IntrMask);
XUartPs_SetOperMode(UartInstPtr, XUARTPS_OPER_MODE_NORMAL);
* Set the receiver timeout. If it is not set, and the last few bytes
* of data do not trigger the over-water or full interrupt, the bytes
* will not be received. By default it is disabled.
* The setting of 8 will timeout after 8 x 4 = 32 character times.
* Increase the time out value if baud rate is high, decrease it if
* baud rate is low.
XUartPs_SetRecvTimeout(UartInstPtr, 8);
return XST_SUCCESS;
int Status;
XScuGic_Config *IntcConfig; /* Config for interrupt controller */
/* Initialize the interrupt controller driver */
IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
if (NULL == IntcConfig) {
return XST_FAILURE;
Status = XScuGic_CfgInitialize(IntcInstancePtr, IntcConfig,
IntcConfig->CpuBaseAddress);
return XST_FAILURE;
* Connect the interrupt controller interrupt handler to the
* hardware interrupt handling logic in the processor.
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
(Xil_ExceptionHandler) XScuGic_InterruptHandler,
IntcInstancePtr);
* Connect a device driver handler that will be called when an
* interrupt for the device occurs, the device driver handler
* performs the specific interrupt processing for the device
Status = XScuGic_Connect(IntcInstancePtr, UartIntrId,
(Xil_ExceptionHandler) XUartPs_InterruptHandler,
(void *) UartInstancePtr);
return XST_FAILURE;
/* Enable the interrupt for the device */
XScuGic_Enable(IntcInstancePtr, UartIntrId);
/* Enable interrupts */
Xil_ExceptionEnable();
return XST_SUCCESS;
XUartPs_Recv(&UartPs, RecvBuffer, RECV_BUFFER_SIZE);
XUartPs_Send(&UartPs, RecvBuffer, 1);
//make sure the TX buffer is empty
while (XUartPs_IsSending(&UartPs));
