usage question of verilog-xl simulator
qjlsy
Member level 3
Member level 3
verilog-xl 2001
1. Does verilog-xl support open files with different way, such as read, write, append? How to run verilog-xl so that it can recognize
$fopen("...","w")?
2. How to let verilog-xl compatible with v2k?
Thanks a lot!
verilog xl 2001
1. NC-verilog supports opening file in read, write, append modes... So I think verilog-xl also do..
2) what is v2k??
verilogxl 2001
whizkid said:
2) what is v2k??
V2K means verilog-2001, verilog-xl is a old tool, so it don't support
verilog-2001. If you codes you verilog source code with some verilog-
2001 feature, the verilog-xl will report error.
wang1
verilog 2001 + xl
I think if you want to use verilog-2001 standard writing codes,you'd better chose nc-sim or modelsim 5.8d or vcs.
