[SOLVED] Usage of vsim in questasim
dhivya34
Junior Member level 1
Hi all,
What is the difference between the following commands?
$ vsim vsim.wlf
$ vsim -view vsim.wlf &
Thanks.
check vsim -help in your unix login. it will give you all the options available with vsim command.
vsim -help gives the various allowed options.
vsim -view vsim.wlf allows us to view the contents of the wlf file.
But I wanted to know the usage of & at the end of the command.
Hei that is not command dependent. it just instructs to run this process(Her your vsim command) as a background process. It is unix related. it will help to easily kill the window if it gets hanged.
