jaykumar.v@somaiya.edu
Newbie level 1
I am doing a project "Agribot" and has facing a problem in interfacing GSM with psoc 5 lp
i saw many codes and i developed my own but its not giving output though successfully compiled
i just tried a code for gsm interface psoc and that too not working
GSM is working with pc hyperterminal correctly but not with psoc
main problem is in code and m not locating the problem. please help
i have copied string.h in directory and used in code.....
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 /* ======================================== * * Copyright YOUR COMPANY, THE YEAR * All Rights Reserved * UNPUBLISHED, LICENSED SOFTWARE. * * CONFIDENTIAL AND PROPRIETARY INFORMATION * WHICH IS THE PROPERTY OF your company. * * ======================================== */ #include <project.h> #include<cypins.h> #include<string.h> void system_init(void); void trans(char[] , int); void delay(uint32); void ring(void); char AT_check[]="AT\r"; char ok[]= "OK"; char rec[]=""; int main() { CyGlobalIntEnable; /* Place your initialization/startup code here (e.g. MyInst_Start()) */ /* CyGlobalIntEnable; */ /* Uncomment this line to enable global interrupts. */ for(;;) { system_init(); //trans(AT_check,3); //puts(AT_check); UART_PutString("A"); int i=0; while((rec[i] = UART_ReadRxData())!='\0') { i++; } //gets(rec); LCD_PrintString("Checking"); delay(2000); LCD_PrintString(rec); delay(2000); LCD_ClearDisplay(); if(strcmp( ok , rec ) || strcmp( "\r", rec)) { LCD_Position(0,0); LCD_PrintString("GSM not Connected"); delay(2000); LCD_ClearDisplay(); } else { LCD_Position(0,0); LCD_PrintString("GSM Connected"); delay(2000); LCD_ClearDisplay(); } /* Place your application code here. */ } //ring(); } void system_init() { UART_Start(); LCD_Start(); LCD_PrintString("Hii"); delay(2000); LCD_ClearDisplay(); } void trans(char tx[], int n) { int i; for(i=0; i<n; i++) { UART_WriteTxData(tx[i]); delay(2000); } } void delay(uint32 d) { uint32 i,j; for(i=1; i<=d; i++) { for(j=1;j<=i;j++); } } /*void ring() { int i=0; while( (rec[i] = UART_GetChar())!='\0') { i++; } LCD_PrintString(rec); }*/ /* [] END OF FILE */
