Urgent!Need Help!Designing Telescopic Amplifier
mindsinmotion
Newbie level 2
Newbie level 2
Hi all,
I need help designing the 2 stage telescopic amplifier using both Bipolar as well as MOS devices.The gain required is grater than 100,000(greatest possible).I will greatly appreciate any inputs like where to use bipolars in the design which will benefit me most.
Thanks
mindsinmotion said:
Hi all,
Thanks
I would use the bipolars in the diferential pair to get higher gm and in the cascode transistors.
Bastos
the input should use biplor, not only higher gm, but also low offset, low noise
the output can use biplor too for low output resistor.
But then where shall I use MOS devices?
By input I think you mean the i/p differential pair.
By o/p do you mean 2nd stage or p channel current mirrors on top of i/p differential pair?
Also how should I bias such a high gain opamp?
What other tricks can I use to ensure highest gain, what about common mode feedback, cascoded stages, or are there any other techniques?
I appreciate your help.
