thanks sv1437.
---------- Post added at 11:22 ---------- Previous post was at 11:03 ----------
Hi sv1437,
well i ve to implement a structure in HFSS wherein i ve to excite my structure with a transient signal. for this i ve 2 options:
1. Export the equivalent ckt from HFSS to any spice software and then excite it with transient signal.
(I tried this, for this i used driven terminal mode of analysis. But when i go for "matrix data" option in solution data under results, the "export equivalent ckt " option is not enabled).
2. Import transient signal data to HFSS and then excite the structure.
(For this we don't ve any clue).
apart from this i ve few more doubts as below:
1. how to connect 2 structures using wires.
2. significance of eigen mode solutions.
thank u in advance......
