hello every body ,
plz help me.
when i simulated antenna in layered bio media then there are some error produced in cst software which are as follows?
"Memory resources exhusted...solver stopped to solve matrix...program aborted"
please tell me how can i remove this error?
one more error:
" the port 1 is inhomogenously filled within the first three mesh cells. cannot start solver"
plz tell me its solution...
for this analysis i use simple three layer human body model (skin,fat and muscle) and when i try to simulate then i get this error" the port 1 is inhomogenously filled within the first three mesh cells. cannot start solver" and for this problem i increased the mesh cells and then this problem is remove but the new problem is come in to picture "Memory resources exhusted...solver stopped to solve matrix...program aborted"
in order to give a matched port and evaluate the mode at the port, CST needs that the waveguide extent inside the calculation domain for three or four mesh cell.
You can do two thing, increse mesh cell (not the best) or extend the waveguide section without curves or angle for 0.25lambda.
