use the dark force on the other side of the moon.. to compute equal ratios and solve
yes and no... small and large hypot. ratios equal side ratios and opposite ratio.. then solve. for unknown h
then square of h= square of opposite + square of adjacent side is extra equation..when needed . then sub. result of one equation into the rest untill you have only h=....
https://en.wikipedia.org/wiki/Hypotenuse#Calculating_the_hypotenuse
Perhaps the original question is: "Explain the difference between a triangle and a quadrangle"?You mention "red triangle", but what I see isn't a triangle.
At least it's the best guess.Ooooo kayyy the simple answer is 2.5
Hello,
