yolco
Member level 2
after generating the Gerber files, and talked with my PCB manufacturer, some modifications need to be done.
Once these modifications are done, I re-generate the Gerber files, but here I have the problem.
Gerber files are not updating, they are the same as previous version.
Does any feature on OrCAD I have to modify?
Is there any step I'm missing?
Regards.
Gerber files are properly created.
The issue comes from PCB Editor which doesn't read the files as it should.
With other Gerber files viewer, all works fine.
- Steps:
- Update & Check DRC Errors.
- Display Status.
- Create Artwork files. Previously, I have matched etch layers, soldermask_bottom, soldermask_top, silkscreen_bottom, silkscreen_top and borderline, for new design.
- Then, I create a new board and import new Artwork files for checking the Gerbers, but they have no change.
Regards.
