DrunkBear
- Joined
- Dec 14, 2006
- Messages
- 108
- Helped
- 11
- Reputation
- 22
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- HangZhou,China
- Activity points
- 2,115
need a patch antenna design with u slot
Once i tried to etch a U-slot on a well matched bottom-fed antenna, the S11 result turned to be extremely bad.
are there any guidelines for U-slot (or other shape of the slot) technique, which is used to enlarge the bandwidth of the patch antenna? Most paper i found just give the final parameters but would not tell the design steps: e.g how the length/width/slot width should be determined.
Any advice?Thank you in advance!
