Updated Potential
Rushmita
Newbie
Hi, I am doing a simulation in CST ESPIC solver, and I am trying to find out the potential change on the surface of the dielectric due to the accumulation of charge. I used post-processing templates to find out the potential. But the potential does not change it remains the same irrespective of how much charge gets accumulated
Verify that your simulation has reached convergence. Convergence in electromagnetic simulations means that the solution is stable, and further iterations do not significantly change the results. If your simulation hasn't converged, you may need to refine your settings or reduce the convergence criteria.
how to check convergence in ES pic solver?
LaTeX Commands Quick-Menu:
