[SOLVED] Update dynamically netlist from Capture to PCB Editor
yolco
Member level 2
Member level 2
I'm just developing my first PCB design, also with OrCAD.
I have started to place components and routed some parts, but I have found several issues that I have to solve into Capture modifying the pins connection of some components.
So, now I need to generate a new netlist file and update the brd file.
  • Is it possible to update it at "real-time? How can I do this?
  • Or on the contrary, do I need to start the board from scratch again?
Moreover, I should have to add some new components to design in future,
  • Could those components be added and exported to board (PCB Editor) without need to re-start the board design?
Regards.
I already found the way, or at least, one way to solve it.
1. Close PCB Editor.
2. Capture. Update Netlist, select the current brd file as input.
2.1 Capture. You can change the output file for making control versions.
2.2 Capture. Generate Netlist.
3. PCB Editor is launched and pins have been reassigned.
What I have no tested yet is adding new components.
Could someone help to know if is this possible? Or explain another better option to do it more efficientl way, also quickly.
Regards.
Yolco,
Add the new components in your schematics and generate the new netlist. Now open the board file which you have worked earlier and import the new netlist in the board file. The new addition of components will get added in the board file from schematics.
Thanks!
It's already done!
When adding new symbols on capture, after generating new netlist, then you have to place the new components in PCB editor, but they are already added to board file.
Regards.
