uPanel or way of faster prototype and easier control
The design described here is a simple, functional and multi-platform device which facilitates creating and testing prototypes. It is a program using which you can quickly define actions in the form of commands sent via COM/UART port. User can attribute previosly defined actions to both buttons and sliders. Program makes it possible to log the incoming data, classify and edit the data immediately due to the support of regular expressions. This design can be useful for everyone who want to improve prototyping projects based on Arduino.
Construction:
Graphical interface of the design uses graphical library swing. It requires Java 1.7 to run the program. To allow the support of port, the design uses library RXTX, which theoretically allows the operation of the program on all popular platforms. The program can be hidden in the communication area as an export of a profile. In addition, user can define the shortcut key for each button. According to the word count of Linux – the sum of lines in all files is equal 4211.
Screenshots:
Useful link: LINK.
To run the project, it is required to instal RXTX library. The file should not be unpacked, but *.zip should be changed to *.jar.
Link to original thread (useful attachment) - uPanel- sposób na szybszy prototyp i łatwiejsze sterowanie
