parveenarora
Newbie level 3
up to 5 volt dc to 220 volt ac dimmer circuit required .pls help
Hi Praveenaroraup to 5 volt dc to 220 volt ac dimmer circuit required .pls help
Your words are confusing . you should try to talk clear to receive best answer . there is a thing in your mind but that is not in my mind . you should try to transfer it correctly . would you like to convert 5VDC to 220 V AC or you just want build a variable supply ? without clear informations i can't say anything .no dc 5 volt to ac 220 volts
Humm , i got the idea ! i think you have a logic stage , which can deliver 0-5 volts out put , and i think you want with a logic system be able to control out put voltage ( AC ) from zero up to 220 V AC . right ?yes inverter circuit with variable output.As dc input very FROM 0 TO 5 volt output should also very from 0 to 220 ac
