[SOLVED] unrouted nets are invisible in altium
Kick
Full Member level 6
Full Member level 6
India,Bangalore
hii all,
In my altium design un-routed nets are invisible.How to enable un-routed nets??. Other designs it is visible. Thanks in advance.
You can try following,
View/Connections/Show all.
or
Check the PCB panel what is the option you have selected from the dropdown menu, you should select the nets.
Rgrds,
Anil
Reactions: Kick
    Kick
