edtruji
Newbie level 5
I'm working with ULN2003AN (DATASHEET),
I'm attaching the ULN2003An to a board call the RXD4 (Board Specifications)., RXD4 come with 2 wireless beepers.
PIN#1 from UNL2003AN solder to PIN#D3 from RXD4.
D3 output 5V 9A when I press the beeper button.
What I need is that when I press the beeper button, the ground should come momentarily on any of the UNL2003AN pins.
In the #8 pin from UNL2003AN, I always have ground and when I press the beeper button the ground leaves momentary.
What I need is exactly the opposite of the behavior I'm getting on PIN8.
I'm a newbie in electronics. Please keep that in mind.
