avib
Newbie level 5
Hi
its my first post on this forum, so i hope i would make everything smooth and clear as possible , im working at pcb debug , and i got a unexplained voltage between 2 GND : 24V_GND and DGND, i cant post the scheme cause of company rules.but maybee directions or ideas will help .
on a working pcb the normal voltage between the 2 layers of GND is "0V" ...on the faulty pcb i get about 10V
the 10v possibly source is from the rs323 flat cable...cause it has been measured when the pcb only connected to RS232 flat ...on a certain pin.)on that moment no 10v between thee GND'S when the pcb is connected to a tester and gets power ...than the GND probly shorted and measured by 10V.. i have some isolaters components which have the both GND (4 channels : power in 24_GND ,power in 2 and DGND. when i replaced those isolaters or remove them the short is still there. i belive it might due to short layers ..but ill be happy for new ideas ..or directions.
if you got any quastions that i can assist you in understanding better ill try .
thank you .
avi.
thank you .
avi.
