Universal Eeprom Programmer
gulson
ssssss
Advanced Member level 5
Poland
universal eeprom programmer
This programmer has been modified by edziu, full discussions can be found here:
You can programmer about 100 eeprom memories very easy - just need switch SW1. How to switch? When you run a program you will see how to switch SW1 (GND or +5V) pins for selected eeprom.
for example 24C16 need switch 4 to GND and 8 to +5V
eeprom universal programmer
Hi!
How about willem? Does this programmer supports 8 pin compatible devices? If so, willem supports lots of devices ;)
Analyzer.
universal eeprom
hi golson
could it possible that you can merge that topic given in under link also please move attachment to here in this topic from the link,also translate it as the lang is polish
