Device ID (DEVID) Registers
Configuration memory space locations 0xFF0000 and 0xFF0002 are used to store a read-only
Device ID number that is set when the device is manufactured. This number identifies the
dsPIC33F device type and the silicon revision.
The Device ID registers can be read using table read instructions.
Unit ID Field
The Unit ID field is located at configuration memory space locations 0xF80010 through 0xf80016.
This field consists of four configuration registers (FUID0-FUID3) and can be programmed with
unique device information
