Unipolar to Bipolar Conversion.
viks
Member level 1
Member level 1
Hi guys
I need to convert a sine wave signal 0 - 3V into -9 to +9 sine wave.
I think I need to use Opamp but I am not able to figure out circuit.
How can I do it?
right now 2 ideas come to my mind.........
design a non-inverting amplifier with gain 6 and
1.connect a 1.5V supply in series with the input
(or)
2. shift the ground by using a 9V supply instead of ground in the resistor connected to the inverting input side.....
    viks
viks , if you don't mind transients - decouple AC by capacitor , or in other case do as Anand suggested.
If 3V bias is sweeping , you will additional DC compensation circuit.
    viks
try clamping it down using a diode and cap. so that you get -0.75 to 0.75. now provide a non-inverting gain of 9/0.75. hope this will work.
    viks
if u would use a diode and cap then we would need a suitable supply to compensate the effect of diode drop and the temperature variation of the diodes parameters.......
