Uninstalling Linux from a two partition PC(boot loader-Grub)
indiaco
Member level 1
Member level 1
Down South...
uninstalling Grub
hi there, i have a question about boot loaders. I installed win xp on my primary partition, and the red hat on the second one.
The boot loader is grub, and i want to uninstall linux from this pc
Here is the deal: can i erase the partition with partition magic and the boot from a floppy to clear master boot record ? will this work like it does with win 98 ?
Should i do this in a different way ? :wink:
THANKS!!
Re: uninstalling Grub
YOU CAN DOWNLOAD "SPFDISK" SOFTWARE
it's free
use dos startup ur machine ,then fdisk /MBR
He can not start up in dos the machine. He must download some boot disk or make one in some machine and and boot the PC via floppy disk
then enter the command "fdisk /mbr"
https://bootdisk.com/bootdisk.htm
like: **broken link removed**
