It is a home made power amplifier UniAmp150 on Toshiba transistors 2SC5200/2SA1943. The construction can operate with Alphard speakers (2xLW800 and TW401). Transistors used should have more than 40W/8ohm. The device was closed in housing Skytec PRO240 „XXL”.
Control transistors used in this project are 2SC4382/2SA1668. Capacitors were connected with the stabilizer directly accordingly to the general schematic without making PCB.
The power amplifier is supplied with a toroid transformer 120VA 2x26V.
List of components:
- resistors
- capacitors
- transistors
- capacitors 10000uF/50V
- rectifier bridge (6A)
- resistors (0R22 5W)
- housing
- transformer
- heat sink (190x70x40)
- fan
Pictures:
Link to original thread (useful attachment) - Końcówka Mocy UniAmp150
