[SOLVED] unexpected IDENTIFIER error , VHDL
emmagood
Member level 4
Can anyone tell me the error in the following code:
entity seven_segment is
Port (rst, clk : in STD_LOGIC;
segment7 : out STD_LOGIC_VECTOR
(7 downto 0);
ca : out STD_LOGIC);
end seven_segment;
architecture Behavioral of seven_segment is
begin
process(rst, clk)
begin
if(rst = '1') then
ca <= '1'; -- for common cathode pin
else(clk'event and clk = '0') --------- error line
segment7 <= "00001100";
ca <= '0';
end if;
end process;
end Behavioral;
the error is : parse error, unexpected IDENTIFIER, expecting AFFECT or EQ or LE
Thanks,
Emma Good
Thanks, that helped. I have one more error problem pls.
entity binary_to_7_seg_display is
Port ( binary : in STD_LOGIC_VECTOR (3 downto 0);
seven_seg_output : out STD_LOGIC_VECTOR (7 downto 0);
rst : in STD_LOGIC;
end binary_to_7_seg_display;
architecture Behavioral of binary_to_7_seg_display is
begin
ca <='0';
if(rst='1') then ------------------------------ error line
seven_seg_output <= "10000000";
elsif(rst ='0')then
case (binary)
when "0000" => seven_seg_output <= "01111110";
when "0001" => seven_seg_output <= "00001100";
when "0010" => seven_seg_output <= "10110110";
when "0011" => seven_seg_output <= "10011110";
when "0100" => seven_seg_output <= "11001100";
when "0101" => seven_seg_output <= "11011010";
when "0110" => seven_seg_output <= "11111010";
when "0111" => seven_seg_output <= "00001110";
when "1000" => seven_seg_output <= "01111110";
when "1001" => seven_seg_output <= "11001110";
when "1010" => seven_seg_output <= "11101110";
when "1011" => seven_seg_output <= "11111000";
when "1100" => seven_seg_output <= "01110010";
when "1101" => seven_seg_output <= "10111100";
when "1110" => seven_seg_output <= "11101010";
when "1111" => seven_seg_output <= "01100010";
end case;
end if;
end Behavioral;
the error is : parse error, unexpected IF
Thanks,
Emma
rst : in STD_LOGIC;
begin
process (rst) is
begin
if(rst='1') then
ca <='0';
else
case binary is
end case;
end if;
end process;
end Behavioral;
You need to include binary in the sensitivity list along with rst, otherwise simulation will likely give erroneous results.
What is up with ca it gets assigned to '0' and nothing else?
Regards
Thanks, problem solved. Added process in the program and it is working.
Emma Good.
