ku637
Hello
For a new design there is a vibration resistance specification of 7G 1000Hz log sweep 15 min/reciprocation duration 20hour.
I'm really new to vibration specs.
May i know how these spec can impact my HW board/circuit design.
I understand for connectors -locable type, Thorugh hole , Flat Ribbon cable may withstand vibration better
and all the big parts (like aluminium electrolytic caps) may be glued to PCB.
And adequate mounting holes for PCB support need to be provided.
Also any other impact of this spec w.r.t other parts selection ? like MCU crystals etc?
Also is this spec on little higher side than what is generally given- my current application is a Motor Drive Circuit
Thanks for any help
Thanks for any help
