FreshmanNewbie
Advanced Member level 1
I have this Dock with me (https://www.dell.com/en-in/work/shop/dell-dock-wd19s-180w/apd/210-azcs/docks).
My question:
1. I want to understand what does the 180W power mean. Does it mean that the dock can give 180W power to the other ports? Or does the Dock require 180W input power for its operation? Or does this 180W will be given to USB Type-C port to support USB Power Delivery to those ports?
2. Just to understand about which USB Type-C port supports fast charging, I was experimenting
a. If I connect, with the host module usb type-c, my mobile is fast charging. And if I connect to the USB Type-C Multifunction DisplayPort , it is also fast charging.
b. But if I connect my mobile to the USB-C 3.1 Gen 2 port, the mobile does not fast charging.
Can someone tell why the two USB Type-C ports supports fast charging and the other usb type-c port doesn't support fast charging?
My question:
