The Rat
Newbie level 3
- Joined
- May 29, 2007
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- United Kingdom
- Activity points
- 1,322
hfss memory usage
Hi all,
Stumbled across this website whilst do some research into understanding the memory usage for large models in Ansoft HFSS v10. I didn't find the exact answer I'm looking for, so I thought I would register and be more specific.
Currently I am (attempting to) simulate an industrial multi-mode microwave applicator, similar to a domestic microwave oven, just considerably larger. The typical dimensions are 1460mm long by 540mm wide by ~650mm tall. The general shape of the applicator is a V-shape with a flat top, and due to the irregular structure of the 8-waveports, there are no planes of symmetry. The frequency of operation is the standard for a microwave applicator in the UK - 2.45GHz.
The Validation process in HFSS states that "Given the specified frequency and model dimensions, an extremely large mesh will be required to produce an accurate solution. Your model and/or frequency units may be set incorrectly", thus confirming my concerns.
So this leads me to ask, is there any way of understanding the memory requirements of my model within HFSS, and ways to reduce these memory requirements of my model so that I can obtain a solution to my problem? I have the HFSS v10 User Manual but this does not allow me to understand memory usage. I have surfed the web for others that have similar problems and they either do not have model problems of the size I am looking at, else they can exploit the symmetry of the problem (something which I cannot do).
My current system specs are:
Windows XP SP2 (32-bit) - the OS set-up is optimised, i.e. only essential
applications are running
Pentium 4 2.2GHz Processor
2GB RAM
However (hopefully) will soon have access to a PC of the following (approximate) spec:
Windows XP SP2 (64-bit)
Dual-core 64-bit Processor
16GB RAM
Any pointers from the HFSS experts would be appreciated. Thanks.
Hi all,
2GB RAM
16GB RAM
