jasonc2
Full Member level 4
I'm looking at the MAX292 active filter datasheet here: **broken link removed** and there are a few numbers I don't understand after getting as far as I could with Google.
Thanks!
J
- Insertion Gain - This means the overall signal gain?
- So if the insertion gain is -1dB, I should expect a 1Vpp input signal to result in a 0.891Vpp output signal?
- The datasheet lists insertion gain in terms of Fo. What is Fo... the corner frequency?
- Since insertion gain is a function of Fo, is this just telling me the filter response curve (it does seem to match up with the frequency response graphs later in the document), or is it telling me some other additional signal loss spec?
- What is DC Swing?
- Output offset voltage is listed as +/- 150mV typical. Does that mean if I were to use this filter to convert PWM to a steady voltage, it could be off by up to 150mV?
- Clock feedthrough is 6 mVpp. Does this mean I should expect a 6mV signal at the clock frequency in the output? That seems high...
Thanks!
J
