Underdamped sine wave generation with thyristor (SCR)
iraquois
Newbie
Newbie level 3
I am trying to generate an underdamped sine wave on 50ohm resistor. To do this I use LC circuit. In my circuit:
First to charge C1. V1 sends pulse and after full charge V1 stops. To have an oscillation V2 sends pulse to U1 ( SCR). But here the problem is I got very short periot of oscillation.
and also second problem is : There is distortion on indcutor like :
How can I extend the oscillation period and how to prevent the distortion?
Or should I change the topology ?
50 Ohms dissipate a lot of energy. While the energy stored in the 6uF is relatively low.
time constant is R x C = 50 Ohms x 6uF = 300us. (This formula does not give exact values for your circuit... but it gives a rule of thumb)
--> so either increase C or increase R to get a higher time constant.
Klaus
Klaus
Even if I remove 50ohm still ringing is too short just adds 1 more period. And values for capacitance and inductance are for to have near 10khz signal. And simple circuit with just L and C gives good ringing.
how do you measure it? With a 50 Ohms measurement tool?
Klaus
consider a diode in series with R1 to limit back-feed into V2 when the SCR fires ...
R1 loads the LC circuit also during negative oscillation period. Better connect trigger voltage source between gate and cathode.
keep doubling C and halving L until the ckt is under-damped ...
also unless you continuously fire the SCR the ringing will stop after the gate drive is removed ....
--- Updated ---
freq - 6.5kHz ( undamped ) the Q of this ckt is very low - hence the lack of long cycle ringing ...
Thanks a lot for all comments. I tried diode with R1 and also connecting pulse signal(V2) to cathode. Still no change.
--- Updated ---
Actually normally if I try to simulate 6uF and 50uH oscillation it looks like that:
So as far as I see values look okey. Problem is in the circuit I think.
I will keep trying to design another circuits and will edit if I can get solution :).
And if you have advice please share. Thanks for all efforts.
