Anton_v89
Newbie
Hello Guys
I just got myself a used oven with a separate stove top.
The stove top is a ceramic one and is connected to the oven via two terminal blocks.
Ofc the previous owner did not disconnect the terminal blocks from the oven but instead the cables them self from the blocks. So now there are seven loos cables that some how are supposed to go into the two terminal blocks. Luckily I was able to order the service manual from the provider. Yet, for me as a non-expert in electrical issues, I'm not able to clearly understand how it should be connected.
***PROBLEM DESCRIPTION***
Cables from Stove top are to be connected to the terminal blocks W1 and W2 (see diagram), the question is what cable goes where? Seven cables from "AR" to W1 and W2 (VDD, VSS, RX/TX, L1, L2, N [blue], N [blue]). W1 and W2 are to be connected to the Oven that supplies power (400V 3N~). The connection scheme is provided from the manufacturer. On the pictures it is seen that all the cables are named, some only on the backside though (the two blue ones, "N" and the brown "L1" and white "L2").
Please see attached pictures and diagram.
Hope someone are able to solve the diagram unambiguous.
Thanks
Thanks
