[SOLVED] Unable to start Cadence Virtusos
emax00
Member level 1
Member level 1
Unable to start Cadence Virtuoso
I have installed IC-615-06.15.151 and MMSIM_11.10.445 but failed to start virtuoso. I am using CentOS 6.4.
When I start the license server using “lmgrd_v” alias defined in bash file it says server is up but the desired vendor daemon is down. When I check the status of server using “lmstat_v” alias it says the license server failed to start.
If I comment out the USE_SERVER line in license file, virtuoso starts but cannot simulate with output log message: waiting for available license for virtuoso spectre.
While configuring MMSIM after IC615 installation, I used the OA installation of IC615 instead of MMSIM. The .bashrc file looks like this:
export CDS_HOME=/opt/EDA/cadence/ic615
export MMSIM_HOME=/opt/EDA/cadence/mmsim111
export OA_HOME=/opt/EDA/cadence/ic615/oa_v22.41.029
export CDS_LIC_FILE=5280@localhost
export CDS_Netlisting_Mode=Analog
export PATH=$MMSIM_HOME/tools/bin:$CDS_HOME/tools/bin:$CDS_HOME/tools/dfII/bin:$PATH
export CDS_AUTO_64BIT="spectre:ultrasim:irun"
alias lmgrd_v='$CDS_HOME/tools/bin/lmgrd -c $CDS_HOME/share/license/license.dat
alias lmstat_v='$CDS_HOME/tools/bin/lmstat -c $CDS_HOME/share/license/license.dat'
alias lmdown_v='$CDS_HOME/tools/bin/lmdown -c $CDS_HOME/share/license/license.dat'
The first few lines of license file looks like this:
SERVER localhost ANY 5280
DAEMON cdslmd /opt/EDA/cadence/ic615/tools/bin/cdslmd
# DO NOT REMOVE THE USE_SERVER LINE
USE_SERVER
FEATURE...
I don't understand where the problem is and how to solve this.
Re: Unable to start Cadence Virtuoso
Just reinstalled the OS and it works fine.
