sureynaresh
Newbie level 1
** Creating circuit file "V1_5025_trial.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.LIB "C:/lm5025-Library/lm5025.lib"
* From [PSPICE NETLIST] section of C:\Cadence\SPB_16.5\tools\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.TRAN 0 1000ns 0
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source LM5025_TRIAL
V_V1 N00436 0 10Vdc
V_V2 N00656 0 40Vdc
R_R1 N01173 N00656 100k TC=0,0
C_C1 0 N01173 220p TC=0,0
R_R2 0 N01681 4.02k TC=0,0
C_C2 0 N01894 0.1u TC=0,0
R_R3 N00656 N02254 150k TC=0,0
R_R4 N02254 0 33.2k TC=0,0
C_C3 N02254 0 1p TC=0,0
R_R5 0 N02561 7.5k TC=0,0
C_C4 0 N00436 1u TC=0,0
C_C5 0 N03383 0.01u TC=0,0
R_R6 0 N01536 100 TC=0,0
R_R7 0 N03978 100 TC=0,0
R_R8 0 N04682 50 TC=0,0
R_R9 0 N04846 50 TC=0,0
R_R10 N04921 0 1 TC=0,0
I_I1 N03566 0 DC 20mAdc
X_U1 N00656 N01173 N04682 N04846 N01681 N01894 N00436 N03978 N01536
+ N03383 N03566 N02561 N04921 N02254 LM5025
**** RESUMING V1_5025_trial.cir ****
.END
ERROR(ORPSIM-15167): Undefined parameter: IC.
In IC description of library, below definition is given.
The simulation takes around 2~4min per 1mSec simulation on a 1.7GHz machine.
*-User can select LM5025/25A/25B/25C by selecting 'IC' of parameter input.
*-For LM5025 device, set IC=0
*-For LM5025A device, set IC=1
*-For LM5025B device, set IC=2
*-For LM5025C device, set IC=3
*-SYNC input can be tied to GND through a resistor as it is not used.
*-Vsupply should have a slope lower than 150V/Sec
*-Pin name of pin#5 is 'TIME' in the datasheet
HOW CAN I SELECT IC=0?
*Libraries:
* Local Libraries :
.lib "nom.lib"
.TRAN 0 1000ns 0
V_V1 N00436 0 10Vdc
V_V2 N00656 0 40Vdc
.END
