ciitv
Junior Member level 2
Unable to run Matlab 7
i'm unable to use matlab 7 on Windows XP SP2 now. when i run the matlab program the flash screen appears and disappears but nothing happens(no
workspace). it was working when i last used it a couple of months ago.even the m file editor and un-install programs do not run now.
i tried re-installing by running the setup file from the cd. but again the flash screen appears and then disappears and no further installation options appear. i deleted the entire matlab folder and i still can't re-install.
the only major change i've made to my comp since matlab last worked is the 1) installed SP2 2)stopped some of the services running on system to make it
run faster. i'd appreciate ur suggestions. thanks in advance.
