Unable to read slave data.
ghoral
Newbie level 6
Newbie level 6
What does data[7:0] mean??
Here , What does DATA[7:0] mean, Do I have to send just (char DATA) to i2c_write function or it should be like (char DATA =0x00).
Re: What does data[7:0] mean??
Data[7:0]= 8 bits of data
* data7, data6, data5....data0.
Klaus
So we just send char data= 0x00 or it should be any specific address.
Are you aware, the we don't know
* what controller you use
* what I2C device you use
* what compiler you use
* what libraries you use
Klaus
Assuming that the I2C address indicates that you are doing a write to the device, then you should be putting in whatever value you need to send to that device address.
Susan
I am using Avr atmega 32 and MFRC522 and atmel studoo.
I am doing project on RFID MFRC522. I have done read and write cycle according to datasheet page 20. I have send device address, and Fifo register address(0x09 datasheet page 36) and 8 bit data. I have done according to cycle But I cannot read the data. I dont know where I am getting ERROR. I think I have used right registers address and function are also ok.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
#define F_CPU 16000000UL
#include <avr/io.h>
#include <string.h>
#include <inttypes.h>
#define  SDA PC0
#define SCL PC1
#include "Lcd.avr.h"
#include "I2C.avr.h"
#include "i2cmaster.h"
//#include "Rfid.h"
#define Write_Address 0x50 //slave addres
#define Register_Address 0x09 //fifo register address
#define I2c_write 0 //write bit
#define I2c_read 1 //read bit
char Data=0x00; //Data[7:0]
void Rfid_Start()
    i2c_init();
    i2c_start(Write_Address+I2c_write);
    i2c_write(Register_Address);
    i2c_write(Data);
    i2c_stop();
unsigned char Rfid_get_data()
    i2c_write(Register_Address);;
    _delay_ms(1);
    i2c_start(Write_Address+I2C_READ);
    Data = i2c_readAck();
    i2c_stop();
    return Data;
int main()
    DDRB = 0xFF;
    lcd_init();
    _delay_ms(100);
    LCD_String_xy(0,0);
    lcdprint("Show your card:");
    Rfid_Start();
    while(1)
        Rfid_get_data();
        LCD_String_xy(0,1);
    //  PORTB = 0xFF;
        lcd_int(Data);
I have no experience with your library functions. But from standard I2C communication:
    _delay_ms(1);
    i2c_start(Write_Address+I2C_READ); [COLOR="#FF0000"]--> here I expect I2C_repeated_start instead of I2C_start[/COLOR].
    Data = i2c_readAck();[COLOR="#FF0000"]--> here I expect to send a dummy byte 0xFF, then read the I2C_input_data_register[/COLOR].
Maybe your library functions do this correctly --> read the library documentation
Or look for verified code examples. I2C communication is almost independent from I2C_slave type, thus no need to look for a MFRC522 code.
Klaus
