unable to locate a C compiler error in matlab
bidarmard
Junior Member level 2
hi everybody
when I run an embedded matlab simulink file by 2012a matlab(64 bit) version the following error appears:(64bit 7.OS)
"Unable to locate a C-compiler required by Stateflow and MATLAB Function blocks. Use 'mex -setup' to select a supported C-compiler."
exactly what should I do to solve this?
I'll be thankful if you kindly help me.
You should have external support of the C-Complier besides being everything ? this Version is not suitable try 2011b .. that is great instead of 2012a or try 2012b.
thank you mushahid your right but how can I have external support of C -compiler in order to use the 2012a version of matlab?
