I came to know that we can directly use the expressions vds and idi to get the intrinsic drain voltage and drain current of the transistor, these are provided by the vendor and they are directly available in the dataset.What are exactly you trying to do ? To measure drain current ?
didn't get exactly what you are saying.I always start my SPICE debug by opening the log file and searching for
the complaint-text or bits of it. From what I see, seems like a results
probe - instance, or command line - has a typo in the what-to-probe.
Don't know how ADS likes to do that, but there's thread to follow in
either the log, the netlist (expanded?) or both.
You cannot measure all those intrinsic quantities of an active device. If you use this option " Show Operating Point" with deeper hierarchy , you can see some deeper currents and voltages as text. Not more..I came to know that we can directly use the expressions vds and idi to get the intrinsic drain voltage and drain current of the transistor, these are provided by the vendor and they are directly available in the dataset.
--- Updated ---
