amiramu10
I am trying to synthesize a simple counter using genus (cadence) tool. I am using Lfoundry PDK library and importing the library. But when I am elaboraing the design it says, "Could not find an HDL design. [CDFG-210] [elaborate]. The design is UD_counter.v". The name of my file is UD_counter.v. Befpre elaboration I have read the file using read_hdl command providing the correct path. It was compiled without any error. My code of counter is very simple
I would highly apprciate any help.
[moderator action: added CODE tags]
module counter(clk,reset,up_down,load,data,count);
//define input and output ports
input clk,reset,load,up_down;
input [7:0] data;
output reg [7:0] count;
//always block will be executed at each and every positive edge of the clock
always@(posedge clk)
begin
if(reset) //Set Counter to Zero
count <= 0;
else if(load) //load the counter with data value
count <= data;
else if(up_down) //count up
count <= count + 1;
else //count down
count <= count - 1;
end
endmodule :counter
