john-nafp
ultraviolet exposure device i built few months ago. it is controled by an arduino pro mini and has a 7 segment display to show the set and remaining exposure time. it uses ultraviolet leds(49 total)bought cheap from ebay.
you can wire the arduino and the rest components using the diagram below.this way i made it too.you can connect any common cathode 7 segment display as long as you know witch pin is the segment shown in the diagram.or you can find it by applying about 3volts to each pin to see witch segment lits and write it down.(as i did)or downloading its diagram if exists..
then programm the arduino with the code given in the link below.you can skip the circuit with the mosfet and the optocoupler and connect a 5 volt relay as shown in the diagram(relay output & ground) to controll the leds.
and here is a video i made on my youtube channel about this project
Arduino code
Arduino code
