Techman_7
Full Member level 2
I am working on ultrasonic barrier project. It has transmitter & receiver. Transmitter transmits 40 KHz FM wave by using two 555 timer ICs. The receiver consist of two LM 567 PLL ICs & a relay that operates when incoming modulating signal is within the capture band of LM567. The transmitter & receiver system works well up to 1 meter only. But the ultrasonic transducer datasheet mention range upto 16 meters. The receiver components for LM 567 are calculated as per datasheet.
But as distance increases the relay chatters. i.e. the modulating signal fluctuates.
Carrier frequency= 40KHz ; Modulating frequency= 220 Hz
Ultrasonic Sensor-Multicomp MCUSD16P40B12RO
Is it because FM modulation index is high?
Can u please help me in this regard......
