Ultrasonic level measurement
hemnath
Advanced Member level 3
Chennai
I'm trying to design an ultrasonic based level measurement. which sensor should i use?
which sensor is best in accuracy?
please help.
asking "which sensor is best" ... but giving not a single specification...
With more than 450 posts you should be experienced enough to give technical data and additional information.
Distance range, medium, temperature range, humidity, cost, frequency, resolution, precision, color, size, availability, power consumption.....
Klaus
Reactions: FvM
    FvM
distance range: 20 meter, medium:air, temperature range: -40 to 60°C, frequency: 45Khz.
Ultrasonic waves undergo an air attenuation of several db/m which makes it rather unlikely to achieve a 20 m range at 45 kHz.
Acoustic level measurement in this range (e.g. for silos) is usually implemented with low kHz audible frequencies. Another problem to consider is temperature dependency of sound speed, also the possibility that the tank/silo atmosphere is different from air. All in all, verify if acoustic level measurement is suitable for your application at all.
Thanks Fvm.
I'll reduce the range to 5meters, if attenuation is higher.
Which sensor should i use.
Thanks milan. The price is too high.
Can you suggest any other sensor with a moderate price. I reduced the measurement to 5meters.
