sole_developer
Junior Member level 3
I'am trying to design a modified version of the Pickit2 Clone. Now, I can't find the PCB Footprints for USB-A, USB-B, Tactile Sitches in Orcad. Hence, I downloaded the Ultra Librarian.....When I search for the item in question, and select it and then click on "Add to Library", It tries to download the component, but after a while I just get the message "ERROR". I have everything designed in Orcad, just need the footprints now..And when I use the PCB Footprints search, it says I need the pro version!
Is there an alternative here? I don't want to start designing footprints man...Anyways, I think I will be moving to Eagle (since most of the components have footprints...)..or is there a better alternative here?
If I wanted to design my own footprints, is there a universal tool I could use to design the footprints from datasheets??
Thanks
Thanks
