ULTRA HIGH SPEED COMPARATOR
blastronics
Member level 3
Member level 3
Between heaven and earth
high speed comparator
I need a high speed comparator that will be driven by a Current output DAC that will transform sine wave to square wave output.
I will use this for DDS based clock generator.
Any suggested chips that will do this job?
thanks
β
ultra high speed comparator
how high? tell the specification
ultra high speed dac
And what technology?
gigahertz comparator
Most DDS have this high speed comparator built inside the chip, but the one that i will use has no buitl in comparator, that why i need an external one.
a.) Differential input with diffrential voltage of 1V pk-pk.( max)
b.) Can switch 0 to 500MHz.
c.) VCC= 3.3V up
d.) VEE=-5Vmax
e.) Vout = LVTTL/LVCMOS , (this will be the clock input of the FPGA)
dds to square wave comparator
GaAs process needed
ultra high speed comperator
ADCMP551, ADCMP552, ADCMP553 are high speed PECL comparator.
you can use them if logic level are PECL, if you use
TTL/CMOS logic level, you can use AD8561, AD8564.
best regards
thanks
β
ultra-high-speed comparators
GaAs? I dont think so. The frequency is just 500MHz
