UL Certification question
Julew
Member level 1
Member level 1
Hello,
I don´t know too much about UL certification. We have a PCB and we sell it in a plastic enclosure without power supply and in a metal enclosure with power supply. Both plastic and metal+power supply are UL294 listed. If we certificate our PCB, the combination of both pcb+enclosure is UL294??? Thanks!
Julen
take a look at this thread: Started by hithesh123‎, 06-09-11 13:18
I don't understand much. Please be a bit clearer.
A power supply can be UL qualified in 2 ways: Open Frame, Plastic case, or Metallic case.
Plastic case
- The plastic must have a Yellow Card issued by UL
- The PS will be Class 2
- The case can be left floating (not connected to earth)
- You can also qualify the plastic case as a FIRE ENCLOSURE CASE. That means that you have to spend a bit more in the plastic material.
Metallic case
- The PS will be Class 1
- The case MUST be connected to Earth
Enrico Migliore
Hello,
Sorry for my vague description. :p
The question is:
If A is UL listed and B is UL listed, is A+B UL?
We have to pass UL294 and in this standard they always talk a system, not about a product. Thanks!
You should ask to a UL safety engineer.
I would say that A+B is not "UL listed" for sure because the UL file number is issued after a test process.
Enrico Migliore
