jhonny_yang
Full Member level 2
Any body have uITron Tutorial ? How to use and program with it ?
whorse said:A general tutorial on RTOS is enough, then what you should do is to refer the uItron user manual
whorse said:Even the uItron is more complex , the basic concept is the same, so just learn the basic function first , and research the advanced feature when you need to.
whorse said:I don't want to talk the uItron is easy or hard, If you think the uItron is hard to use, then you should change you decision, for example, eCos, RT-Linux uCOSII which are well documented, like what you said.
Don't compare yourself with others, every person has different background. Always choose the way best fit you.
