rf1008
Full Member level 2
Hi all,i'm just simulating tag antenna by HFSS and find the BW issue.
I want to get 100M bandwidth(860~960MHz) of return loss below -10dB,but it's not easy,very hard! 860~930MHz or 900~960 is easier which means 60~70M BW. Is anybody has the same concern about it? No matter what the antenna pattern is. Thanks.
B.T.W, return loss is calculated by formular of power reflection efficiency here, CAN'T be calculated by HFSS itself because the S11 formular is wrong.
