Gaber Mohamed Boraey
Full Member level 4
Hello
I've built this circuit
I hope it's clear enough for you
I've biased with 12-15 v, the Vcc pin, and here is the signal shape I've got on oscilloscope on the pwm pin, the IC output pin, and Vref by the way is 5v
And here are the readings
As you see, no pulses at all,
Is it something wrong with the circuit?, or my scope settings or what!, although I've got the scope calibrated before measure
How can I add led to the circuit to check if light with pulses and use as reference to know that the IC is good or bad beside the scope signal?
